RCU Forums - View Single Post - Parkzone North American T-28 Trojan
Old 04-13-2007 | 10:50 AM
Bigtone's Avatar
Bigtone
Default Parkzone North American T-28 Trojan
PKZ4400 T-28 Trojan RTF $219.99
http://www.horizonhobby.com/Products...ProdID=PKZ4400
More Pic's
http://www.horizonhobby.com/Products...KZ4400&Index=0
Key Features
Ready-to-fly right from the box
High quality, reusable 5+ channel ZX10 radio system with 3-wire servos
Steerable nose gear and fixed main landing gear allows for smooth ROG’s and landings
11.1V, 1800mAh Li-Po battery offers high level of performance and power
Variable rate DC cell balancing Li-Po charger safely charges and conditions Li-Po battery
480, 960Kv outrunner brushless power system
E-flite 25A brushless ESC
Durable Z-Foam™ construction
Authentic paint scheme, decals and pilot figure
Overview
The T-28 Trojan was a piston-powered U.S. military trainer used in the 1950’s through the early 1970’s. The original Trojan had a frameless canopy and an impressive engine that gave it a top speed exceeding 280 mph. Now you can pilot a ready-to-fly, electric scale replica of this historical warbird. Equipped with an outrunner brushless motor and 3-cell 1800mAh Li-Po battery, ParkZone’s T-28 Trojan is a powerful, high performance aircraft. The Trojan is perfect for the experienced pilot who would rather spend his time flying a mighty scale replica airplane than building one.
The T-28 Trojan is also available in a Plug-N-Play version. The convenience of a Ready-To-Fly and the versatility of an Almost-Ready-to-Fly—just plug in your receiver and fly! You can fly the T-28 Trojan using any major brand of receiver and transmitter. Simply attach a propeller and plug in a receiver of four channels or more, and it’s ready for action.
Charge-and-Fly convenience, outstanding flight performance and beautiful scale detail with the T-28 Trojan you get it all.
Specs
Wing Span: 44 in (1118mm)
Overall Length: 36 in (914mm)
Flying Weight: 30 oz (875 g)
Motor Size: PKZ 480 960Kv outrunner brushless motor
Radio: 72 MHz 5+ channel FM proportional ZX10
Servos: 3-wire servos
Speed Control : E-flite 25A brushless (EFLA1025)
Recommended Battery: 3-cell 1800mAh Li-Po battery (PKZ1031)
PKZ4475 T-28 Trojan PNP $159.99
http://www.horizonhobby.com/Products...ProdID=PKZ4475
Key Features
Specs
Trim Scheme Colors: white with black, red, and blue
Prop Size: 9.5 x 7.5
Recommended Battery: 3-cell 1800mAh Li-Po battery included (PKZ1031)
Available Frequencies: 6 channels on 72MHz
Charger: DC variable rate cell balancing 2-3 cell LiPO charger
