RE: Hobby-Lobby International Dragonus II, new & improved
Servos mounted... I've got all four of the Hitec HS65HB servos intalled in the frame. Next up I'lll bre fitting the motor and determining where the pinion needs to be on the motor shaft. I may grind a small flat on the motor shaft for the pinion set screw.
Here's a pic of the servos mounted...
