RE: Matrix / Genesis tyres
The filter and the foam are the same.
While you technically could mount the Genesis rims on a Matrix Arena, it's not a good idea. At least not with the stock gearing. Make sure you change to a shorter gear ratio. Also something that I'm not so sure of is whether you will have full steering throw (probably so, just not sure).
