RCU Forums - View Single Post - rough idle question
Old 04-13-2007 | 10:13 PM
bruce88123
Default RE: rough idle question
STOP the engine and make 1/8 turn adjustments. It would be easy to go right past the correct point if you make larger changes. Try to remember total changes made so you can go back to the starting point if that is decided to do for ANY reason, Normally the hole should be ABOUT 1/2 blocked.
