RE: Hangar 9 Twist 3D Part II - Thread Continuation
ya, try each servo to make sure its not a problem with the servo, if all your servos work, then its either a problem with the reciever, or a problem with the mixing on your radio. I know you are using a y-harness but, Is your radio digital, or do you have to work dual servos with a y-harness?
