RE: Engine Mounting-can someone explain thrust?
Most (well, maybe many, but those I've built latery have) kits (arf's) have the engine thrust offset built in to the firewall. Check you kit/arf specs to see if it's already there. If that's the case, you only have to mount the engine and go from there.
DS.
