RE: Engine Mounting-can someone explain thrust?
"The manual shows by diagram 1 degree down thrust and 5 degrees right thrust. Does this indicate to point the nose of the engine UP 1 degree and left 5 degrees to achieve this?"
I don't understand how you could possibly come to this conclusion. You state that there is a clear cut diagram to follow. The engine points down and to the right as viewed from the cockpit.
