RCU Forums - View Single Post - Engine Mounting-can someone explain thrust?
Old 04-14-2007 | 04:32 PM
garland66
Default RE: Engine Mounting-can someone explain thrust?
Of course not all manuals are created equal. The engine mounting section gives the dimension for the engine distance to fit the cowl, but does not mention anything in text about thrust angles, only that small drawing. There's also no specs stating that the thrust angles are built into the firewall. I think I'll just mount it straight on the engine mount (which by the way came mounted on the firewall from the factory) then take some measurements to check!
