RCU Forums - View Single Post - Spinner problem
Old 04-14-2007 | 06:09 PM
bruce88123
Default RE: Spinner problem
More torque. Do NOT use a lockwasher as it will lose it's effect after it's first use and need replacing after each use. Also not the same quality of steel as the other hardware. Also do NOT use threadlockers. I use an 8 inch combination wrench of the correct size so there is NO wrench slippage. Tighten it down, you won't hurt it.
