RCU Forums - View Single Post - rough idle question
Old 04-14-2007 | 07:01 PM
mbilar1
Default RE: rough idle question
ORIGINAL: bruce88123
Assuming that I am correct. You need to lean the engine. This is an air bleed carb and the idle mix screw works opposite to most "standard" carbs. There is a small hole in the front of the carb that lets in air to mix with the idle fuel. There is also a screw that comes in from the side that PARTIALLY blocks this hole and regulates this air flow and thus the MIX. Turning the screw CW closes the hole makes the mixture more rich. Conversely turning the screw CCW opens the hole and leans the mixture.
ONLY MAKE SMALL (1/8 TURN) ADJUSTMENTS OF THIS AT A TIME. THIS IS VERY SENSITIVE.
OK Everything seems to be working OK, but when it's idling, if I lift the plane to vertical while idling, it runs for a 5 seconds then dies. At full throttle and vertical, no problem, only at idle speeds. Does this mean the idle is too lean? Or is this normal for idle to die when vertical?
