RCU Forums - View Single Post - SOLDERING 101
Old 04-14-2007 | 10:46 PM
bobthehobo9
Default RE: SOLDERING 101
is the tip clean on your iron? if its dirty then it is not able to transfer heat well...
does the solder melt and then just bead off of the connector?
i guess you can try heating up the connector/wire more before you apply solder..
it takes practice to get really good at soldering... either that or im just stupid
