RCU Forums - View Single Post - rough idle question
Old 04-14-2007 | 11:33 PM
mbilar1
Default RE: rough idle question
ORIGINAL: bruce88123
It's NEVER normal to die. You may have gone too far to the lean side. These air bleed carbs are VERY sensitive PIA's.
So in theory I need to turn Idle richer until it doesn't die when vertical? Another symptom is that when I back down the throttle to idle (not including the trim to kill it) it gradually slows down over 15 or 20 seconds. Still a fairly rough idle. Could it be it's still too lean? As I turn the screw I noticed it turns very easily almost as if vibration might have got it out of whack in the first place.
I suppose the next step might be to RTFM that came with it to set everything back to factory reccommended.
