RCU Forums - View Single Post - warbird servos
Old 04-15-2007 | 01:33 AM
gnx168
Default RE: warbird servos
You can use your 3004 for throttle, flaps, retracts " the air valve", elerons if one in each wing. As for the elevater especally if its split use the 645's and the rudder also because the tail wheel will need alittle athority on the ground. The 3004 has plastic gears so its a matter of time before they strip.
