RE: Sig Tri Star Build
After studying the plans you need to be carful placing the servos as the threaded block to hold the belly pan will be placed here later and can interfear with the servo case.. The rails were fitted and glued. Using a Futaba 3004 for the steering and an HS 225 for the elevator.
Then SANDING AND MORE SANDING [&o]to shape the fuse. Use a copy of the plans to place on the nose with 3M 77 adhesive to help rough shape. This was done from the top and side.
Canopy fitting was a PITA. [X(]Do the main canopy on the hatch first then the front and rear matching the center canopy's height and profile.
