RE: Bearing puller
Well, hopefully the short duration at 450 degrees meant that the aluminum cases never completely reached that temperature and the durability of the aluminum wasn't compromised. I'll find out when the engine has run for a while, I guess. I do know that the bearing would not come out after heat soaking at 350 for between 10 and 15 minutes which is why I kicked up the temperature. I'll keep you posted.
Al
