RCU Forums - View Single Post - Do sizes of gloplugs make any difference?
Old 04-15-2007 | 06:00 PM
bruce88123
Default RE: Do sizes of gloplugs make any difference?
That fuel mix is often referred to as FAI fuel. Used a lot, I'm told, thoughout Europe. If the +/- plate you are talking about is the idle mix plate on the Perry carb it can be removed (pulled out) and the o-rings lubed or replaced.
