RE: WHAT ARE THE KNOWN PROBLEMS WITH MUGEN MBX5
box stock nothing except the leaking diff o rings, but the ones from carolinas RC & you won't have any problems.
when you build it grind a notch in the pins for the CV joints so that the grub screw can bite into it, & use GOOD locktite & you'll reduce the risk of throwing a CV pin.
