RE: Evolution 61 off Alpha 60
If it's like the Alpha .40/.455 all you have to do is use a bench vice and a socket.
Open the vice jaws far enough so the prop driver can be knocked out the bottom of the flywheel when you lay it across the jaws...
Use a socket that is just the right size to fit (slightly smaller than the hole in the flywheel) and tap it with a hammer to pop the prop driver out the bottom...ya follow me?
