Need help finding this Receiver, PLEASE HELP?
All right Ill try to sum things up
SYSTEM COMPONETS:
Model: System V2C-2SH PCM
Transmitter: Net-V122 PCM
Receiver: NER-832X
Servo: NES-507 x 2
Accessories: BEC Switch harness, Battery case, Servo rubber, Band Flag
The speed controller is fryed(didnt care for it much anyways if I can recall)
And yes, The Receiver is AM PCM 27MHz
Heres what the manual said about the receiver;
BEC (BATTERY ELIMINATOR CIRUITRY) RECEIVER
*Receiving Range: 200M Ground, 400M Air.
*Power source of Receiver and Servo obatained from the running battery porvides stable current flow. It does not require to install receiver battery separately.
*Easy to install and prevent the trouble caused by mis-wiring.
*Nely developped JR Regulater does not allow self-running.
*Size: H21 x W33 x D51 (m/m)
*Weight: 36g
*AM PCM ABC & W System
Rodney: to anwear your quistion.. It says PCM so Im guessing its PCM...
Ill try to scan a photo of the receiver tonight.. So you all can check it out...
Ladyflyer: Thanx for telling me about that.. But Im sure sendin it in wont do any good... (I was stupped) and ran my Stadium Blitzer on the pond (over ice in the winter) and found a slushy spot and thats when it screwed up... But I was also running 2 7.2V batterys at the same time on the reciever (big no no, I know)((But I learned the hard way, besides I was young and stupped))
JohnBuckner: Thanx for your post too...
Hopefully I cleared up some things here...
Time to dig out my scanner...
