RE: Strong enough?
if the firewall is only glued onto balsa, then i don't think it's strong enough. a 120 will pull that clean off. i'd rather not take the risk. the firewall should be of at least light ply.
the servo mounts, however should be okay as long as your screws screw through hardwood or ply. a 120 size shouldn't have anything mounted to only balsa. my two cents.
