RCU Forums - View Single Post - X-Treme Composite OTOP - YS 160 Pipe Setup
Old 04-16-2007 | 08:15 AM
tommy s
My Feedback: (55)
Default RE: X-Treme Composite OTOP - YS 160 Pipe Setup
Nikos,
I used the NMP header from Central Hobbies which will work with the Hatori pipes as well.
The header aligns the pipe dead center in the pipe tunnel. Just a note on mounting the engine;
on my OTOP the nose is angled for right thrust but the firewall is installed square so I had to
make a shim to angle the Hyde mount the correct amount for the desired right thrust. I used
an ES Composites carbon fibre pipe which is fairly long but I believe any length pipe will work.
tommy s
