RCU Forums - View Single Post - Engine Purchase Questions
Old 02-21-2003 | 04:21 PM
Bax
Default Engine Purchase Questions
The O.S. nomenclature for pull-start engines has an "X" as the designator. A "(P)" means the engine is equipmmed with a pilot-shaft type of crankshaft.
The pilot shaft is the way to retain the clutch/flywheel assembly, and has nothing to do with a recoil starter. European R/C cars tend to use the pilot shaft crank, as to a few of the Japanese R/C cars.
The O.S. Max RZ-series cannot be converted to recoil starting.
The .21 RZ has two versions, pilot shaft and non:
OSMG2065 13860 .21 RZ-V01B
OSMG2066 13861 .21 RZ-V01B (P)
