RCU Forums - View Single Post - Flaps on a King Kobra
Old 04-16-2007 | 09:39 AM
BillS
Default RE: Flaps on a King Kobra
The King Kobra and the Kougar are similar designs by the same person. If it flies like the Kougar flaps won’t be necessary. With the balance forward and the ailerons reflexed the Kougar will fly like an advanced trainer. Shims at the wing bolts for more up incidence will tame the airplane down even more.
If you like to experiment servos for each aileron in the center of the wing are possible with only minor modification. Then flaperons would be possible.
Dirtying up the airframe a very slight amount will tame the flight characteristics. Gradually the dirty techniques can be reversed and the airplane will go like a bat out of hell. With a clean airframe it tends to land fast. Wing incidence when sitting on the ground should be negative so it will stick when landing.
I have several Kougars and one is 17 years old. I also have a King Kobra, which is waiting for calmer wind for initial tests.
Bill
