RCU Forums - View Single Post - Balsa USA Eindecker
Old 02-20-2003 | 04:24 PM
big max 1935
My Feedback: (9)
Default Balsa USA Eindecker
It is so far from scale why worry with the wires! They have the landing gear too far back, axle should be right under leading edge. The wing mounting block broke on mine first flight,make a new one out of REAL plywood ,with 1/8" plywood on both end . Also move it down about a 1/4". Put top & bottom sheeting at 45 degree angle on fuse ,much stronger. Have been flying mine 5 years with a G-23 on it, don`t know how they will be able to balance it with a 91 glow engine, must own a lead mine! Put a tail wheel on it! Good flier , does all WWI maneuvers with grace.
>>>>>>>>>>>>>>>big max 1935>>>>>>>>>>>>>>>>>>>
