RE: New Patriot XL
Hello Kmtranmd,
Thank you for your reply. I actually put a 1650mah battery in the tail and I still have to add some weight to balance it properly. I fly form a paved runway, so I might be able to use a 12" propeller. Do you think a 12" would be better than an 11" prop. on this airframe? I mounted my nosegear as long as I could, I even put a shim between the gear and the mounting platform, but it is still slightly "nose down".
Anyway, thanks a lot,
Le fou
