RCU Forums - View Single Post - AXI 5330
Thread: AXI 5330
Old 04-16-2007 | 12:35 PM
woodie's Avatar
woodie
Default RE: AXI 5330
ORIGINAL: rgreen24
What do you guys think the best prop is for this motor. Tried the 20x13 but did not feel that it had enough speed. ANy other props you guys can think of? Also did not set the brake, and had a difficult time landing the bird with the prop free wheeling. Will adding the brake help with this?
TIA
I'm running the std Jeti 90 and 77 with my AXI 5330/F3A (235 kV). I believe the Jeti defaults to 24 degrees timing if set in outrunner mode and I have more than enough power and speed running 13" pitch props. 12" is great in calm air, 20X13 or 21x13 for some breeze and 20x15 for WINDY. The plane is ballistic with the 20x15......
If you are running the low kV 5330, you might want to try a 14" or 15" prop.
Don
