RE: big problem
it does sound like a compression problem, though. I have had the same problem on a 2 stroke go cart engine, adn it was compression. Just double and triple check everything. try checking the carb, and make sure you have a 1mm carb opening, and no more.
(sounds like you wore out your oil groove on the piston)
