RCU Forums - View Single Post - Aileron issue...
Old 02-25-2003 | 03:03 AM
CafeenMan
Default Aileron issue...
TX-Deck - Congratulations on your flight success. I've noticed the PT trainer is kind of sluggish making a turn into the wind as well. Since you are aware of it, then you just have to keep in mind that you have to start making the turn earlier than you would otherwise.
Also, you may want to consider putting an 11-5 prop on your .46. It will give you a better climb and reduce the top speed. Also, it will accelerate a little better. Just my 2 cents worth.
Congrats again. Bet you feel a lot better now that it's flown.
