1/4 scale sopwith pup kit covering problem
Reg,
Thanks for the feed back,i understand what you mean,but until i come to the covering stage,i shall try afew tests,just to test out the theory!!!.
Heres something else ,on the tailplane/rudder,is it just one single rib wire,or is there another one underneath?to form rib outline, or are they just used as spacers,but allowing the covering to form aerofoil,hope that makes sense!!
How far in construction are you,me ,i have a model to finish,then i can make a start!!
Eindecker
