RCU Forums - View Single Post - air bubbles / fuel lines.....KILLIN' ME !!
Old 04-17-2007 | 09:27 AM
JEFFRO503
My Feedback: (9)
Default RE: air bubbles / fuel lines.....KILLIN' ME !!
ORIGINAL: piroflip2
hi JEFF
none of my glow fuel motors suffer from bubbles in the fuel lines and will (if I let them) run fine untill the tanks are empty.
balance your prop, wrap your tank in a softer foam.
if you need a header tank for your engine to run properly there is something wrong with your set-up.
btw "little saito 125's " and "smaller glow fuel motor's",,,,,,,,,,,,,,,give me a break pal!!!!!!!!!!!
well............they are kind of small compared to what i've been flying anyways hehehe !!
I have a 35% WH sukoi coming and a BME 115 with a set of cans that are gettin' lonely and dying to be ran.
BUT......on the exceptionally large glow fuel motor's ( is that better ? ) i have a problem with them getting the air bubble only about every 7-8th flight....just enough to screw with my confindence that day. I'm going to look into those better clunks and also that little 2oz sub-tank a guy mentioned above....that's some good advice i can use.
As far as the damage goes......besides my funtanna 100X , there are two guy with the same plane also. We really wring these little sucker's out , and with the throws set on 40-50 degree's , the little sucker will just about flip inside a 8' raduis , over and over , and over.......pretty sweet!! The damage.........it just tore off the landing gear and that was it. the other two guys have had the same thing happen when they came in on a pretty hard landing.
Get this.....The 2" X 5-1/4" X 3/8th thick block for the landing gear...popped out really clean. And just like the other two guys said , it's only put in with CA , not epoxy........or the epoxy was put on extremely light. I didn't even get any wood splinter's between the two block. The block was in perfect shape and still attached the the landing gear , with no damage to the airplane , except for where the wheel pants went through the covering.
The other 2 guys said their's did the exact same thing.......i asked them why the heck didn't they mention this before? I would have slapped on some epoxy and saved myself a headache.HAHA!! Oh well.....thanks for all your advice guys...i'm looking into both the clunk and the little sub-tank idea's today , get er' all set up and tear it up again next weekend ( <<< figure of speech ).
Jeff
