RCU Forums - View Single Post - Head temp on 4 stroke?
Old 04-17-2007 | 10:23 AM
AMB
Default RE: Head temp on 4 stroke?
The factory advice from Bax should be followed 100%. one point is really the KISS principal if cannot see or feel oil coming out the exhaust on any engine 4 strk , 2 strk
or diesel LACK of lube, things will wear pretty quick If the engine is not overpropped and has good cooling over it will be fine . too lean --overpropped --not enough air flow
over the engine. it will have a short life. and of course exceeding the max rpms stated in the directions which is usally caused by under -propping martin
