RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 04-17-2007 | 02:46 PM
  #3264
MIXMASTER's Avatar
MIXMASTER
My Feedback: (15)
Default RE: U Can Do 3D
I use an APC prop & lay it on top of the Zinger, trace the APC tip onto the Zinger & cut with fine razor saw. The tricky part is sanding the airfoil section after the cutting, the trailing edges are flat and thicker after the cut, you have to match the inboard part of the airfoil.
