Spring air only good for lighter gear and no gear door.
If the wire or strut got little sticky somewhere. It will not come down.
Both air system is the best. Ofcourse until it leak...[:@]
ORIGINAL: Crazy4Flight
ORIGINAL: seanreit
ORIGINAL: tamjets
Run brake on seperate system.
Just incase you loss air on retract. You still had brake.
Tam is clearly joking here to me, so you lose air in your retracts, exactly what are brakes going to do for you? The paint job has now become your brakes!!
Spring Airs will drop if air pressure is lost.
then the brakes are the brakes
