fail safe
rcav8r
Right. It will lock in the last position IF Fail Safe is NOT programmed. Failsafe is a programmable function on my Prism 7x , low throttle, slightly up elevator, neutral rudder and ailerons. Nevertheless, I was at over three hundred feet of distance today cycling the RPM's etc and not a wiggle of glitch in 30 minutes run time... Progress is progress. As I stated, I'll return to troubleshooting the source but that PCM receiver will be back in that plane long term
I'm one happy camper...first progress in 15 range test trials. I suspect that when rcign delivers the shield I'll see the FM band range I need. THEN I'll drop in the PCM and test fly. Read my pledge a few posts back.
Sincere thanks to all for your interest...
