RCU Forums - View Single Post - Head temp on 4 stroke?
Old 04-17-2007 | 07:37 PM
AMB
Default RE: Head temp on 4 stroke?
I do not know if will be of any help but here goes with the engine in a round cowl and even if you have a 'dummy engiine' fill piece of you cut out the area where the engine is to to same size as the cylinder will blend in fine you most however have an opening somwheres twice that area to let the cooling air out martin
