RE: Extreme Flight 88" Yak - Build and Fly
I figure if the Amsoil at 100 to 1 is good enough for the pro guys using on the 150 cc engines, it is good enough for my smaller gasser.
I have been using Amsoil for my Automotive, Aviation, and small 2 stroke engines for a little over 20 years now. You just can't beat a good synthetic. BTW did you guys know that synthetic lubes is the only material that will work in a commercial jet engine? Different formulation for sure but synthetic just the same. Synthetics are formulated to take the extreme temps and pressures and excell dino oils.
Yak Man, how are you liking the Zoar prop? What kind of rpm range are you getting from it?
