RCU Forums - View Single Post - E-FLITE BLADE CP PRO
Old 04-17-2007 | 10:13 PM
  #1654
mrasmm
Default RE: E-FLITE BLADE CP PRO
ORIGINAL: Junktim
Thanks for the tips. I'm guessing the 8t pinion is to lower the gearing since the PlastiBlades are heavy. Does that just extend the life of the motor?
yeah, no prob. It will extend the life of the motor by making it run less hot, and it will also be easier on your battery and make flight times 15-20% longer =) I noticed about a 2 min increase from 10 min (so 12 total) with the stock battery, and about 3 min increase with my 1250mAh pack from 15 to 18 min.
I used to live not too far from you in Encinitas =P
