RE: Mico ballons and epoxy & epoxy and paint
I've found that when using epoxy and microballoons as a filler, after its in place, use a piece of wax paper over it to smooth and feather. Leave the wax paper in place until the epoxy is fully cured (8 hours) then just peel it off. It will leave a nice smooth surface that should very closely match your final profile. Really reduces the amount of sanding required.
Brad
