RE: New Patriot XL
KC,
The Magnum 91 XLS instruction manual recommends a 14X6" for break in. I am not sure exactly what prop will be my "definitive" prop on the patriot. I was thinking of starting with a 12X6" and then experiment. So, I should use a 12X6" for the first few minutes of break in and then use a 11X6"? Do you thnik I will see a big difference in performances if I use the recommended 14X6" for break in?
Le fou
