RCU Forums - View Single Post - sturmtiger painted
Old 04-18-2007 | 01:07 PM
shenlonco's Avatar
shenlonco
Default RE: sturmtiger painted
Thanks Guy's!
James she runs she just pulls to one side when driving even when i have the trim set all the way to try and correct it.
Maybe i will shoot a little video of it running on my deck out back and post it up.
PS James ...Don't you always say you burn up the speed controle part on the HL board all the time that controles the motor speed?
If so if the part has a # on it you can buy the same part and solder it in directly on the board in the same way as the stock part...another words it would be like having 2 of the same parts on the board..... I do this with fets on my Mini Z boards what it does is makes you be able to run hotter motors... so if you do it to the tanks you should never blow the speed controller again.
