RCU Forums - View Single Post - Tractor or Pusher
Old 02-22-2003 | 02:56 AM
Ben Lanterman's Avatar
Ben Lanterman
Default Tractor or Pusher
Graupner (I think) and Astro Flight in the past have had pusher motor/props on glider wing configuration airplanes.
I had one of the Graupner motors and the props were a low speed design and were spring loaded to fold and trail behind the motor pod/wing without power.
The pod was essentially the same diameter as the motor and was faired into the wing. It extended a few inches aft of the trailing edge. It worked well.
