RCU Forums - View Single Post - Will it burn?
Old 04-18-2007 | 07:44 PM
JustABigKid
Default RE: Will it burn?
I bought a regulator value for the Coleman propane tank:
http://s43500.sites99.storefront-hos...ail.aspx?ID=50
You can just plug in the gas line to the turbine and open the value one click when the turbine first spins up. It works great and doesn't require an onboard tank or ECU valve...
