RE: Hangar 9 Twist 3D Part II - Thread Continuation
Thanks ... i have had the cg at different places. not sure if i have been at that range. I just trashed mine the other day. it done one of its famous nose up attitudes. I forced nose back down ... wind caught it and tipped wings to the left. the wind was gusty and turbulent ... corrected and it flipped to right instantly hitting the right wing tip on ground.
when it started to do the tumble, as the fuse started over the top, it busted iin half before it ever hit the ground. they are built flimsy, and unstable. nose up at 45 degree angle when you try flaring to land. first plane that i ever had that the fuse was so flimsy that it will break in half with out hiitting the ground! first plane that i have ever had that would point its nose up at 45 degree angle and float down the runway @ 45 degree angle till it just stops flying and falls out of the sky if you let it.
Bruce
aa2dd
