El Cheepo GWS on the throttle and HS-81's everywhere else. I just bent mine last weekend after I changed radio systems... Yup you guessed it... Preflight check; "everything moves, check, let's fly"... reversed ailerons[:@] That's okay the purple was getting old. so I will recover the entire plane and see if I can lose some weight in the proccess. If anyone is interested in the rebuild, more so what the frame looks like without the skin I can post some pics when I get her stripped. My main goal will be to eliminate the 3/4oz of lead on the tail so I will modify something
