RE: Saito .82 Spinner Adaptor Issue
foosball, I had the same problem with my Saito 100, and Ken and Bruce both told me the same thing that Ken just told you. What I did is screw in the screw as far as it would go into the nut, then marked the last thread I could see. I unscrewed it and cut off that much of the screw with a Dremel, from the mark I made to the end. It worked perfectly after that.
