RE: Koverall--First Time User Needs Help
One last caution that I don't think was mentioned. DO NOT use a heat gun to shrink the polyester coverings (Stits, Koverall or ETC). You do not have control over the temperature. You may over stretch the fabric which will either result in a crushed structure as learned by johnvb -RCU or the fabric going past shrink into slack again, from which there is no return. Use an iron with temperature control.
