ORIGINAL: aerowoof
what type of material is the horn made from nylon.is this an arf?you could try a larger screw or add a nut after the plate
I would go with the new mini machine screw and bolt idea with a nylon/plastic backing. With a good sharp xacto tip or small drill bit to drill the hole.
