RE: Jetronic retract valve
Harry you are right . The jet tronics will dump the air when turned off. A servo robart type valve set up will solve the problem. I use them in the bvm F100 and have no problems. It you have quality retract units they should stay locked with out air and the electronic will be fine. Good luck Dan Avilla
