RCU Forums - View Single Post - Stripped Screw
Old 04-19-2007 | 02:17 PM
scratchonly
Default RE: Stripped Screw
I would not trust a wood screw in balsa for anything, let alone a primary control.. as advised use a machine screw and nut for all the holes, peferably with a thin plywood on the surface opposite the horn. Are you sure there isn't a nylon plate on one side?
