RCU Forums - View Single Post - Receiver/servo voltage 12 Volts?
Old 04-20-2007 | 09:10 AM
pilotpete2's Avatar
pilotpete2
Default RE: Receiver/servo voltage 12 Volts?
Stu,
If you are going to be using two 6 volt lead acid batteries in series all you have to do is wire your reciever harness across one battery, rather than across the series pair, 6 volts is fine for the receiver and most servos.
Pete
